Question: Olympus T-32 Flash
dcsang
Canadian & Not A Dentist
11:00 AM
Toronto Canada
I've been looking at snagging one of these flashes used (for a reasonable price) and before I do I had a question about it.
On the rear panel I've seen the flash with the "Full Automatic Control by OM2" panel and the "Calculator" panel.
What I want to know is, is this the SAME panel? (i.e. can you remove it and "flip it" over to use as the calculator panel if you do not have an OM2 or other OM camera?)
I'm looking at this flash as a "fill" flash (low profile) for the M7's and, potentially, if the voltage isn't nutty, for the X-Pro1.
Thanks,
Dave
Turning the panel over to "full ttl" side and sliding it back in does nothing more then set the flash to full manual mode. Full manual is ttl (otf ((off-the-film)) mode. John
