Question on film names....
DNG
Film Friendly
9:45 PM
Indianapolis, Indiana. USA
I am looking on eBay for film, and came across:
Ilford Pan 100 and 400
Any different from Delta 100 and 400 here in the USA?
I have not seen Pan 100 and 400 in USA stores like B&H...
I shoot Pan 50, available in the USA
In my experience, Pan 100 = fp4+, Pan 400= hp5+. I don't know if they are exactly the same, but I can't distinguish the results.
Delta refers to Ilford emulsions with flat (or "T") style grain, in same vein as Kodak's Tmax series.
The Pan series have the traditional grain technology. In some instances. the emulsions marked "Ilford Pan" are the original, unimproved version. That's not necessarily true now; about a decade and a half ago, Ilford sold two types of HP 5: their HP5+ was the premium, non Tgrain, 400 BW, and Pan 400, the original HP5 emulsion.
Pan should mean the film is panchromatic and is more sensitive to certain portions of the light spectrum. And it also indicates older film technology.
The TMax and Delta films use cubic grain, I believe. I don't know whether their light sensitivity spectrum is identical to panchromatic films.
I would expect it to be similar.
Pan 100 and 400 are not FP4+ and HP5+, as ZorkiKat pointed out they are more similar to the old ("not plus") FP4 and HP5. They are grainier and less sharp. They are sold as student films in a limited range of markets. They have very different developing times.
Delta films use epitaxial grain, not flat grain.
T-Max films use monosize flat grain technology. Delta films use monosize epitaxial grain technology. Acros and other films use monosize cubic grain technology. Most 'traditional' films are cubic grain films with a broad range of grain sizes i.e. they are not monosize emulsions.
It is possible to make grains of each kind sensitive in any kind of way; this is mostly achieved using sensitizing dyes.
Marty
... T-Max films use monosize flat grain technology. Delta films use monosize epitaxial grain technology. ...
Hey Marty,
Perhaps you could explain this to me further. From my understanding flat grain and epitaxial grain are not mutually exclusive. Because of the technology in achieving the crystallization of the silver halide, an epitaxial layer may be thicker than a "flat" crystal layer, this isn't a necessity, right? I have worked in the CVD industry and an epitaxial layer was one in which the crystals in the layer all had the same orientation.
In photographic film, this would likely have the effect of maximizing the crystal's cross section as photons passed through the emulsion. While a flat grain that is not epitaxial might have silver halide crystals at differing orientations, some of which would be less than optimum. Because of this, the epitaxial arrangement of the Delta films would be more efficient photon grabbers. Am I thinking about this correctly?
Hi Chris,
You're right up to a point. As occurs often the use of the terms isn't precise and as usual manufacturers tell us what they think will impress us.
A t-grain emulsion has flat grains:
and in Kodak's t-grain films are monosize emulsions (the spread of grain sizes is narrow) with the grains in the same (or a narrow range of) planes. But Kodak don't tell us how they lay the emulsion down.
Ilford's "core shell technology" emulsion has rhomboid grains that are grown around a core of a slightly dissimilar material, with more depth than t-grains - I can't find a picture of it right now, but I know there used to be some on the web. Epitaxy refers to the method of depositing a monocrystalline film on a monocrystalline substrate, and epitxial refers to of, pertaining to, or employing epitaxy. This describes well how the Ilford film emulsions are made and is a way to orient the grains in the emulsion. Ilford's Delta emulsions most correctly are monosize core shell epitaxial emulsions, but are called epitaxial by many, even by some engineers involved with making it who I've spoken to. The main reason to make an epitaxial film emulsion is to ensure that the grains all have a similar orientation, but there are other ways to achieve the same thing. So we know a bit about Ilford's grains and how they are laid down.
In that sense you could make an epitaxial t-grain film, but Kodak don't tell us if this is how they apply the tgrain emulsions. The rhomboid grains that Ilford uses makes their films ever so slightly grainier than flat grain films, but with better latitude. Kodak's flat grains have less time, temperature and developer latitude than Ilford's core shell ones.
You can also make a monosize cubic / traditional grain film. Acros is one of these.
The grain orientation does not necessarily make them automatically more sensitive, because sensitivity is largely determined by sensitization dyes and incorporated development accelerants in modern films.
Additionally, strictly speaking, when your chemical vapour deposition industry people talked about an epitaxial layer, they were referring to the means to get to the end, not the end (the crystals in the layer all having the same orientation) itself.
I hope I explained this clearly.
Marty
