N
Nikon Bob
Guest
This is my first post in the Russian camera forum and likely long and boring. I had a Kiev4 with meter hanging around for awhile. I checked it out and all the functions seemed to work except the timer was inoperative. The lens filter ring has a few dents form some hefty hits and the lens wiggles in the mount, in short dragged behind the proverbial army truck. I loaded with KM 200VX and shot it at 100 asa in very bright/contrasty conditions with no hood. All alittle tough on the old girl. I was very pleased with the results considering what the camera has been through. The only real problem is an intermittant light leak from the top of the frame. Should I be looking at the seals at the bottom of the camera? There also appear to be light leaks around the sprocket holes at the top of the frame. I also played with the meter and found that it would agree with my Sekonic incident meter if I set the film speed dial to 65 on the Kiev when using 100 asa on the incident meter. The 50/F2 lens is horrible into the sun from flare and no hood. I may have to check it for internal haze too. In short I think it performed very well for an old beater. Any suggestions on fixing the light leak? I have attached some photos of the usual handy subjects, nothing artsy fartsy, which also shows an example of the light leak.
Nikon Bob
Nikon Bob
