Krzys
Will the frame lines correct for parallax if I mount the older ltm mount Voigtlander wide angle lenses which have no rangefinder coupling?
ferider
No, sorry. Parallax correction is done via RF coupling. Only the LTM 12, 15 and 25 Snapshot Skopar are uncoupled. Meaning, only the 25 will pose a problem, since for the other two, framelines are missing. 21, 28, 35, and 50 LTM Skopars, Ultrons and the Nokton are all coupled.
Krzys
Thanks a lot. I thought that the 21mm LTM was uncoupled...will check.
Edit: Neat it is coupled, thanks.
