kb244
A couple weeks ago I lent my Argus C3 to a classmate who still doesn't have a camera for film class, but I hadn't had time to actually test it so in a way I felt bad for lending an untested camera and for her coming back with a mostly blank roll with weird radial light leak in two or three parts of the roll (which makes me think either it was exposed in the tank, or the back was opened briefly before the film was rewound). And many many many of the framed seemed overlapped, dragged, or just no correct spacing at all. Essentially was thinking camera-error. (She's now borrowing the professor's Pentax K1000 as of a couple days ago, and hopefully she gets some usable images out of that).
I loaded up an expired P3200 roll which I have a lot of, since it's sufficient enough for testing since I know I have to use 400EI to yield a dense enough image to counter the darker base density it produced from age.
Other than my focus needing to be recalibrated (it's closer than the focus point I put it on), and overlapping just the first and second frame when I first loaded it, it seems to be well... trouble free. So I'm thinking user error in this case, but it's not exactly an "easy" camera compared to say just a wind-and-shoot SLR. Easy enough for me, but I been shooting for like 18 years.
I won't get around to wet printing until we're back in the lab on Tuesday, but this is just a phone picture of the negs on the light table and inverted with curves in photoshop to give sort of a rough look at all the frames shot. (Last frame on the 4th roll is multiple exposures as I forgot briefly for a moment I need to wind in between shutter cockings).
And some selected scans with some photoshopping for contrast and color tone. (I usually like to see what I can get digitally, then compare it later to what I managed in wet printing, especially when trying to match the contrast).
Focus point : Top of the church (though this would been the f/16 out of the aperture bracketing, so pretty much covers it all)
Focus Point : The "40" on the wall
Focus Point : Doorway (Actual : Ended up closer to the light pole closest to me)
Focus Point : Vending Machines (Actual : ended up on the bench on the right near me)
I left the C3 in my locker, so when I get back to school, probably Monday, I'll tripod it, and stick it out the 4th floor south window so I can calibrate infinity to the church steeple a couple miles away like I did with my Canon 7.
My only gripe with the C3 in my brief playing with it, is that I don't have some kind of a neck strap or some kind of way to just let it swing when I'm handling other things like the little Gossen Digisix or another camera.
I noticed the captured film area seems to be larger than what the viewfinder provides. And that the frame width from one gap to the next is pretty spot on in my negative carrier for the scanner, it just seems like it captures a slightly larger image than my other 35mm cameras do.
