haring
I have removed card/RAW photos from Canon DSLR, renamed photos and without changing them moved back to card and inserted camera. Canon DSLR can't recognize photos...It can't play them. Why? Anybody can explain this? Thanks!
venchka
The new names don't follow Canon's naming convention. Did you also change the file extension?
Why did you rename the files?
Do you delete files from the card or format the card when you fill it up?
Wayne
Sent from my iPhone using Tapatalk
Wayne
haring
I have tried to rename them back. Doesn't work....
I wasn't thinking that renaming will have an impact....
Yes, deleted the files after transferring them...
venchka
From the Digital Gospel According to the Internet and people I trust:
Format. Never delete.
Buried somewhere in the Settings Maze is a place where you can specify a 3 character prefix for the filename. I use my initials.
Never delete. Format.
Did you also change the 3 character file type extension after the period?
Format
Wayne
Format
Wayne
dmr
Registered Abuser
I never really used a digital camera until 2009 or so, and since then I'm still climbing the learning curve, so to speak. Currently I'm playing with RAW files vs. .jpg files and getting familiar and comfortable with them, slowly that is.
Of course I've received much sage advice from the earlier adopters of digital, some of it very wise and valuable, and some of it, of course, questionable.
1. Do all of your "write" operations (format, delete) in the camera and not in the computer.
2. Don't delete too much. This in terms of that it's usually OK to delete onesy-twosey to get a few more shots in, but don't push it. Re-format when you want to delete all.
The BEST advice I ever got was to not futz around with the cables, but to get one of those card readers and directly transfer the files to the PC. "{F-bomb} the cables!" was a direct quote.
Another, which is almost intuitive, is right after each shoot, copy the files to the PC to have a clean backed-up copy in case anything goes wrong.
Other advice which I've followed is not to try to use cards from one camera to another without reformatting, and to always use name brand cards from a known dealer and not Ebay specials.
That's the collection of advice I've been following and so far I have not lost a single {crossing fingers, knocking on wood} image to a technical error.
