Leica LTM Removing speed dial on a 111C
convman
10:24 PM
Anyone able to tell me how to remove the speed dial on a wartime 111C. Its been fitted with the wrong one at somtime and I have the correct one to replace it. I have removed the grub screw but what else is necessary.
If there is only one grub screw - the knob should then unscrew itself (normal right-hand thread), but may be tight & need a ring-wrench to grip it.. If you have 3 grub screws, it should just lift off, but that would more likely be a IIIf knob..
What`s the serial number on the camera? Just curious.......
Tom
