repairing an olympus 35 SP
douwe
Jazz and Silver
8:50 AM
Amsterdam
I recently bought an Olympus 35 SP, and I want to get it into shape again. I need some advise on o couple of things:
  • How to adjust the rangefinder
  • How to clean in between the lens groups
  • How to properly clean the viewfinder
  • How to check the metering system
Let's start a tread and try to get a lot of know-how together about the oly SP, a wonderful fixed lens rangefinder!
Douwe
douwe, if you would spearhead compiling the info from previous threads that addressed these issues, that would be a good first step.
The horizontal RF adjustment is accessible from the interior of the camera. Open the back. Above the top rail you will see a round hole. There is a small screw that is recessed and lets you adjust the RF in the horizontal plane. The vertical adjustment requires removing the top plate; I've never done the vertical adjustment (haven't needed to), but others here have and it seemed easy enough.
If the lens needs disassembly to clean between elements you'll need appropriate spanner wrenches for both the front and the back, IIRC. It's not a job I'd want to do as I don't have a collimater to insure the lens is properly reassembled. YMMV.
