RF calibration for Mamiya 6 and 7's ?
mrisney
10:34 AM
Portland, OR
I know this has been asked before. Is there a recommendation for RF calibrations for the Mamiya RF'ers ? I would gladly send my Mamiya 6's and accompanying lenses out to someone who does this, in the back of my mind the MAC Group (75 Virginia Road, North White Plains, NY 10603) doesn't do calibrations at a decent price, or do them at all, is that right ?
I have picked up 150 for my Mamiya 6, it definetly is not calibrated, my first roll back, images are a mess, not so with the 75mm, should the 50mm be calibrated as well ?
Thanks
My Mamiya 6 needed to be recalibrated and some other minor work done on it after a few years of moderate use. I sent it off to Mamiya in Westchester - they did the work efficiently and did a fine job. I was not outraged by the price (although I do recall that it was expensive).
You may not need to have the lenses calibrated at all, as the lenses may be properly calibrated to begin with. You may simply need to have your rangefinder adjusted. The 150mm with its very limited depth of field is much more unforgiving than the 75mm and 50mm with regards to the rangefinder being very slightly off. The 75mm and 50mm may not be affected by very slight focusing errors at all, while it may be glaringly obvious with the 150mm. Before sending your lenses out to be calibrated, I would check your rangefinder accuracy by mounting the 150mm, the 75mm, and 50mm and checking each of their infinity focus against a full moon in the sky. I did this with each of my four Mamiya 6 bodies, and made the appropriate rangefinder adjustment as necessary and now they each work great with my two 50mm, one 75mm, and one 150mm lenses.
Also, you absolutely should use the moon as your infinity target, as using a distant building is not far enough to adjust the rangefinder in the Mamiya 6.
