maddoc
... likes film again.
After some time I have used my Noctilux again and all what I got were photos showing severe front focus. It was my M4-2, which had been sent out for service (35mm frame lines did not appear anymore) in autumn of last year. I got curious and found that infinity was way off but didn`t realize this problem earlier since I used the camera mostly at 2m distance setting and with 35mm lenses stopped down. For occasionally out of focus photos I blamed my technique.
Now the problem is, I tried to adjust infinity (the outermost eccentric screw in the cam follower) but wasn`t able to do so. With a lens (any lens that I tested) set to infinity I was not able to adjust the RF correspondingly.
I then went to Leica Ginza (Tokyo) last Saturday and asked if they could have a look and adjust the RF of my M4-2. When I returned to pick up the camera I was told that also the technician wasn`t able to adjust infinity, that something must be out of specs and the camera would have to be sent to Leica Wetzlar for repair. I was quoted about JPY 150000 (about US$ 1270) for that repair if a new VF/RF is required ....
Now I was wondering if the adjustment problem might be solved by adjusting the relative travel distance of the RF arm (the second screw with an eccentric washer) first and then infinity ?
I would need some ground glass to check also close focus and would be interested to hear if anybody has adjusted the RF of his M Leica this way?
