Ricoh GR Digital II battery life with AAA NiMH. Hmm.
Dante_Stella
Rex canum cattorumque
10:59 AM
I ran a quick test of the GR Digital II with 2 x Energizer 800Mah NiMH AAAs. Much to my surprise (or maybe not), the camera got through over 200 pictures (non-flash). Test condition was with SanDisk Ultra II 2gb, indoors, with about a 10 second interval between shots.
My test with alkalines was pretty true to the 35-40 frame figures I have seen.
My surmise is that MiMH cells are much flatter across their discharge cycle, although they (nominally) start at 1.2V - and alkalines start high but rapidly dip below the voltage that the camera sees as "ok." I had a similar experience with one of the early Konica "flat" (folded optic zoom) p/s cameras that took AAs.
When I get a chance, I will measure the start and end voltages for each type of cell.
The NiMH thing (assuming it is not a fluke) is big - since you can charge 4 AAAs in 15-30 min (assuming you are not worried about shortening the battery's life cycle) - and it takes a couple of hours to fully charge a DB-60 battery. Good emergency power. This also says good things about the survivability of the camera after DB-60s are discontinued.
Has anyone dropped in the Energizer E2 Lithium AAAs? How did that work out?
Probably very good
Probably very good
for a 2 AA camera. All the P&S's I've owned use AAs or proprietary batteries.
I've used dozens of name brand and generic NiMH's and like the Sanyo Enerloops quite a bit, though for toys or applications where I may not recover the batteries, I like cheap alkalines, usually < USD $0.20 each in bulk.
I bought a pack of AAA lithiums for my GRD over Thansgiving when I realized I'd left my spare battery and charger at home. I haven't been overly impressed with the Ricoh battery, and am very unimpressed with the generic spare, so I needed the insurance. Oddly enough, I went that whole weekend on the one battery.
So, long store short, I'll let you know ;) I keep the lithium AAA's with me now, so I'll need to use them eventually.
