Ricoh GRD cracked LCD
wilt
5:02 AM
The LCD on my Ricoh GRD cracked. The camera still works, but it seems I'm stuck with the settings the camera was in when it broke (changing settings without seeing the menu is a bit difficult).
Suggestions for solutions welcome!
Best is to contact Ricoh and see how much a repair would cost.
You can also connect the camera to your TV or computer via the video out, this will give you a live view from the LCD. While this is not a practical solution to go out shooting, it can help you make adjustments so you can set it to some default settings that would work in most situations (e.g. ISO 400, JPG+RAW, Options when pressing Adj. etc.). If you find a small enough device that has a TV-in port you could take it along when you're out shooting.
