Right angle finder for Bessa R?
Swift1
11:38 AM
This will likely sound kinda odd to most of y'all...
Does anyone know of a right angle finder that will fit the eyepiece on the Bessa R, and if so, is the entire viewfinder viewable through the angle finder?
I have a Pentax Refconverter-A and it is slightly too small to fit the Bessa eyepiece.
Any help is appreciated.
Colton
Nikon DR-3, made for the Nikon F, F2, and F3 non HP, FM, FE, FA, etc.
Or
Nikon DR-4 with the DK-13 adapter.
http://www.nikonusa.com/fileuploads/pdfs/RtAngleFind_050511.pdf
The beautiful thing about the Bessa R cameras is that they take the Nikon eyepieces, and hence the Nikon eyepiece attachments. This also works for the medium format cameras!
That is, the Voigtlander Bessa III / Fuji GF670, and Bessa IIIW (Fuji equivalent).
I don't know how much you're going to see, but since they are meant to show the entire SLR screen, you should see the entire viewfinder.
Or
The Bessa R doesn't have the round threaded eyepiece that the later Bessa cameras have.
Do you know if the Nikon DK-22 adapter will fit the Bessa R?
its likely any of the universal right angle finders meant for Pentax/Ricoh/Minolta will fit the bessa. Brands like Focal and Sears.
I bet the DK22 would work, if not a little sanding on the inner tabs might make it work. I would try it!
Sorry Colton,
I've only got my Bessa IIIW to go on, here in Arkansas. I left my Bessa R in Chicago. However, I do use the Nikon DK-21M magnifying eyepiece on my Bessa R (gives 1.17X magnification).
This eyepiece was made for the D40... D600 series.
I see that the DK-22 adapter was also made for these same cameras, so it should fit the Bessa R. You can then screw in the DR-4 into the DK-22.
Another alternative you may want to try is the Seagull:
https://www.amazon.com/Seagull-Find...TF8&qid=1491874317&sr=1-2&keywords=nikon+dr-6
If it doesn't fit, you can always return it to Amazon.
Sorry Colton,
So, by the handy Nikon chart that I gave you earlier, MAYBE the DR-6. However, that is a darned expensive item!
For less than half the price of the DR-6, you may want to try the Seagull:
Thanks guys. Gives lots to think about :)
I like the low cost of the off brand universal finders, but worry about optical quality, especially viewing through the rangefinder/viewfinder.
Dear Colton, dear Robert, and dear all:
Did someone eventually try the combo Nikon DR-3 plus DK-22 adapter on a Bessa R or R2?
If yes: is the DK-22 adapter robust enough, or does one have to improvise?
I never did try any right angle finder on my Bessa R. I just mostly use my wheelchair camera mount and either guess the framing, or if I have someone raise the mount, I can just barely get my eye on the finder. I probably should invest in an angle finder setup.
Dear Colton,
I have an idea, and not too expensive I hope —— see here:
https://rangefinderforum.com/forums/showpost.php?p=2850996&postcount=40
... I have to add: there are some good old (and quite weighty) right angle finders around, and can often be purchased really cheaply. Not kidding: these no name right angle finders like on the pictures in the other thread are of very very high quality, but: most sellers don't realise who the manufacturer/distributor was then in the 1970s ...
And they work on a rangefinder, particularly on my Bessa R2, like a charm! —— In my case with the original Voigtländer «Double Accessory Shoe, Type C», hence the question whether a 3 D print would be feasible...
There's a nicely priced Olympus angle finder at a local store. I will check and see if it fits my Bessa R.
Mostly just for composition.
Kodak and Leica made a couple different ones that were very cool. I think Nikon had one too.
You need to troll sites that don't know what they are selling all the time (e.g. ShopGoodWill.com) to find deals.
I went for sports finders some years back and found them.
Google right angle finders and look at images for examples. Kodak Ektra was one that I remember.
There are usable ones and others that are, well, less usable. To me the ones from the SLR world are not as usable, but that's me.
Hope this helps.
B2 (;->
Confirmed that the excellent Olympus right angle finder does not fit onto the Bessa R. Really too bad because that finder is really nice and bright and crisp.
