Rollei 3.5f light traps
JWalker
12:59 PM
Years ago, I replaced an upper back seal near the hinge with black yarn, but is starting to wear out? Am I missing any other light trap areas? Any diagrams or pictures of where sealing material is needed? I do not think leaks are from other areas except the back. Thanks!
We should have a rule that anybody starting a thread about light leaks need to post a photo showing the light leak...
Not getting leaks so far, but I would like to know where any seals would need attention in the future. The only area I can see is at the hinge area where the back can be disengaged. Thanks!
That is the only seal on the back.
There is a felt light trap around the back of the lens where it enters the body, but this is only an issue if you remove the lens board, etc.
