Rollei 40/2.8 LTM wobble?
roundg
11:55 AM
Last month I got chance to check a Rollei 40mm LTM. It has serious wobble issue that the whole front part is quite loose.
Is it a common issue for this lens? any easy DIY to fix?
None with mine, either.
You might as well ask the question about the CV 28/3.5 as well, for it shares the same barrel.
Tiny, solid lenses.
I googled about wobble issue of this lens but can't find any record/discussion on this lens. I suppose the lens is in very good build quality. But the one I viewed has a very loose front.
I had no problem with the CV28 I used to have.
