Rollei AFM35 filter???
vfrazz
vincent
7:19 PM
I'm getting more use from this Rollei as I work with the manual controls and the various electronic settings, and I've fashioned a push-on yellow filter from a found filter and tape. But as the tape wears, the filter falls off. I've measured the outer diameter of the lens barrel and bought two filters from eBay, but they just don't fit. Anyone discovered a good-fit push-on brand/source?
www.vincentfrazzettaphotography.com
Thank you for asking this question, and you are in luck! Your query motivated me to try out the Leitz 36mm slip-on filter that I have for use on the 50f3.5 Elmar and 35f3.5 Summaron. Guess what? perfect fit. These filters are readily available used.
Exposure compensation will have to be dialed in on the camera.
