Samyang / Walimex / Rokinon 12mm f2 NCS CS Fuji X
  • Thread starter TKH
  • Start date
  • Replies: Replies 0
  • Views: Views 6K
TKH
9:11 AM
Thats what Samyang says:
Features
The black, Fujifilm X mount Rokinon 12mm f/2.0 NCS CS Lens is a prime wide-angle lens designed specifically for use with APS-C sized image sensors. Providing a 35mm-equivalent focal length of 18mm and a broad 98.9° angle of view, this lens is well-suited for architectural, interior, and landscape images. Its fast f/2.0 maximum aperture is further beneficial to working in low-light conditions.
Three extra-low dispersion elements and two aspherical elements have been incorporated into the optical design to minimize chromatic aberrations and distortion in order to produce sharper images. Additionally, a Nano Coating System (NCS) has been applied to the lens elements in order to reduce surface reflections and prevent lens flare and ghosting for improved light transmission and more contrast-rich imagery.
  • Prime wide-angle lens provides a 35mm-equivalent focal length of 18mm, making it ideally suited for architectural and landscape subjects.
  • Fast f/2.0 maximum aperture benefits working in low-light conditions.
  • Three extra-low dispersion elements and two aspherical elements reduce chromatic aberrations and distortions in order to produce sharper images.
  • Nano Coating System improves light transmission and suppresses lens flare and ghosting for more contrast-rich, color-neutral images.
So here we have a low price, around $400, and ultra wide lens that gives a 18mm view on our Fuji cameras.
Foto 2 von rainerduesmann auf Flickr
Foto 3 von rainerduesmann auf Flickr
f2
f2_Gang_-5114 von rainerduesmann auf Flickr
f2
f2_Kerze_-5128 von rainerduesmann auf Flickr
100% Crop
f2_Kerze_100%Crop_-5128 von rainerduesmann auf Flickr
Very niceh bokeh:
DSCF5119 von rainerduesmann auf Flickr
DSCF5112 von rainerduesmann auf Flickr
f2_-5134 von rainerduesmann auf Flickr
Building is very well, sharp from f2 in the middle and up to the corners from f4.
A lot of bang for the buck!
Rainer
