Searching for an A4 lightbox
Matus
2:42 PM
Ok - I am in the market for a new lightbox with area of A4 (about 10x12") or a bit smaller.
I have had a small model from Kaiser in the past and it did not last long, so I am not too keen on buying their product (though I should say that it was a low-end model)
I am located in Germany and would prefer to buy locally online (easier to return the product if I do not like it)
I had a look at what is out there and found few products, but as these are mostly marketed for graphic purposes (slide viewing is 'out') I am not sure about the color reproduction:
- Soligor SV-300 Pro (area is only 20x15 cm)
- Artograph LightPad A930 (LED, A4)
- Copic Comic Master Tracer (LED, A4)
And that would be about it. I like the idea of LED lightbox as it would probabluy last longer and produce less heat, but what about the spectrum?
Please do feel free to propose a model if you have good experience. I would like to fit under €200 probably though.
thanks
And I just ordered a used Rodenstock aspherical 6x loupe for a good price so a nice light box is now a must.
So - any advice on which light box to get (or not to get)?
Their smallest model (38x35 cm area) is about 700 €
That would be the smallest of their very fancy dimmable ones. Nice to have, in particular to match the brightness of a monitor used in parallel, but only mandatory if you do advanced pre-press work.
The plain constant light ones further down the page start at 178€, for the same size.
Thank you - I did not scroll the page down :rolleyes:. Indeed - that is reasonable price. I will have a closer look.
The Kaiser Slimlite (20x30) from Fotoimpex at 143 euro maybe?
I have seen that one, but the lightbox I have was from Kaiser and I was not too impressed by the built-quality (though my model was smaller and cheaper, but this one looks similar).
Aha - okay. It looked nice, though. But reality is what counts! :)
The other one I know of is Microlight, but I've no idea if you can find it in Germany.
As a matter of fact I managed to find it in Germany. And the price of 118 € is on the lower end. Do you have any experience with it? How is the illumination and built quality? On the sale-webpage is stated that it should deliver 5000 K +/- 300.
One small update from my side. I just found the information about the light temperature on the LED light-box Copic (Comic master) - and it it 9.000 Kelvin. So - concerning the rest of the LED light-boxes without specifications on light temperature I guess they are too around that value.
The bottom line for me is - LED light-boxes are most probably (unless explicitly stated) way too cold lin light temperature to be comfortably used for slides.
I will most probably get one of the simpler (cheaper) models from Normlicht as those look solid.
