Selfmade hotshoe for Canon 7?
Spider67
10:29 AM
Vienna
Hi I bought a Canon 7 from a member. I wanted it as a beackup for my Bessa R and althugh I saw it has no hotshoe for external VF's I bought it.🙄
Has a nyone aselfmade solution for that? Could you (pretty) please post some of them for inspiration (and no a Canon 7s is not waht I am looking for😉)
Thanks in advance guys
Regards from Sunny Rhodes
Des (usually Vienna)🙂
Thanks Jim but as those attachments are in the sphere of "unobtainium" (copyright Karen Nakamura) I am looking for a selfmade workaround that I can copy if allowed.
I have seen some homemade attachments, that resembled the Canon version, over the years. All were based on the same idea, the attachment point was the flash contact on the side of the camera. Most of these were (crudely) made of metal but I even saw one made of wood. I've also seen some enterprising folks glue an attachment shoe to the top of the camera.
Jim B.
hey if you want ill loan you mine, then you can attempt to make a copy,
you will need an old flash for parts to steal its mount.
right now all i can get is the other adapter. its a lot shorter (not centered on the camera) and only for flashes
Canon also made an accessory shoe adapter for the Canonflex that will fit the Canon 7. It is small and bayonets onto the side flash mount. The shoe is good for an offset flash setup, but is too far from the lens for a finder. This little adapter is much less expensive than the special Canon 7 accessory shoe.
David
David
thats the one i said i could find. i know kevincameras has at least one. and there are more...
Here is mine. I use it all the time for my CVII meter and a 24mm finder. They line up fine with the picture frame. It pops off in two seconds for changing the film and is very secure. I never use the shoe on the edge. If I need a to use a VF and the meter at the same time, I use the double shoe adapter I bought from Stephen, our bartender.
I had three options with the bracket. 1) Make one as I did. Cheap, fast, and easy. 2) Make it where it attaches by a bolt into the threads that hold the flash sync port and bracket. That would entail a 5 minute episode every time I would rewind the film. 3) Spend $150-$250 on the Canon made bracket. I might have had to wait years for one!
I made the DIY adapter out of stock aluminum from the hardware store ($5), four #4 CS metal screws from the hardware store ($1),accessory shoe from the camera store ($7.95), and a flash adapter bracket from eBay ($10). I put felt on the bottom, even though it does not touch the camera top plate. It took about 2 hours of work. I also spent an extra unnecessary three hours color sanding and polishing the aluminum stock to make it shine like a mirror.
There is one Canon 7 flash adapter bracket for $9.90 now on eBay. A flash unit V will also work. They both can be found from $5 - $50.
