Leica LTM Semi Stand Rodinal Disaster
mikepry
Mike Pry
8:14 AM
I have recently aquired a Leica lllc and thought I'd try to do semi stand development with Rodinal. I thought this would be a great way to get in the ballpark so to speak with 36 exposures/roll not always having the same lighting situations. I am coming from Large Format work in 8/10 where I use BTZS to expose each sheet individually for the given range of light.
Anyhow, I used Fomapan 200 rated at 100 (wanting to insure good shadows) exposure read with an incident meter and developed the film for 1 hour at 1:100. I agitated for 15 seconds initially and then 15 sec. at 1/2 hour. 70 degrees throughout. The result ...... impossible to print! These things are so contrasty that even after one full minute @ f/4 on my enlarging lens my shadows go to ink and the highlights don't even start to come up yet! So.......... thinking of the old adage, expose for the shadows, develop for the highlights am I safe to assume that I simply developed to long or perhaps should of been 1:200? Or maybe I should use the box speed of 200? I would appreciate any help anyone could offer. Inspecting with a loupe shows me good shadow detail so should I perhaps cut the time in development or rather just increase dilution?
Thanks in Advance,
Mike
an hour is about the same amount of time I would use to push TriX to 1600... so I'm guess it's just too much time for 100/200.
You might be able to recover some of the detail with a really good scanner (one with a high-dmax and multipass scanning).
I have in fact scanned and I can get an acceptable image from that (on the Mac) but I print in the darkroom. I'm thinking to either up the dilution or reduce development time. I will do ONE thing at a time so as not to confuse things, you know.
The obvious solution is less time. I would start next at 30 min.
You need not commit a full roll. Find a full range subject, make 6 exposures, pull out 12 inches of film in the dark and process just that much.
