Setting exposure on Kodak signet 80
Blooze
1:27 PM
I picked up a Signet 80 a while back and was hoping someone could confirm how to set the exposure on this camera?
The built in meter is read in EV (there are f-stops on the bottom of the lenses, FWIW). Anyway, first I set the shutter speed, then I turn the ring that adjusts the EV settings until the metal "brackets" are selecting the shutter speed. Then I move the front knurled ring until the needed EV reading is in the window. If I can't get the EV reading I need then I start all over with a different shutter speed adjustment. Does this sound correct? I always want the brackets to select the shutter speed selected?
Thanks for any help ;)
Here's a link to the manual. Just wanting a double check of my reading comprehension. My manual is the updated version where you substitute the brackets for the index dot.
http://www.cameramanuals.org/kodak_pdf/kodak_signet_80-1.pdf
