Shallow question: short/long silver lens for M240?
Dante_Stella
Rex canum cattorumque
1:26 AM
"I have CDO. It's like OCD, but the letters are in the right order."
So for reasons that seem to boil down to color coordination and may only be fully understood by a psychiatrist, I use lenses with my (silver) M240 and (black) MM246 based on what matches the camera. I also have a ton of black lenses I use with very low frequency.
The M246 pretty much lives with a 21/4.5 ZM or an MS Sonnetar 50 on it. Sometimes an 90mm M-Hexanon. Or a 28mm PC Nikkor.
For the M240, I generally use a 35mm Hexanon L (E46) with a 50mm Sonnar-C (E46) or Hexanon L (E40.5). But I feel like this needs a third focal length. If you had to pick a third silver lens for this, based on external aesthetics and some pretext of additional functionality, would you pick:
  • 18mm ZM (which I have in black but would be sweet in silver instead);
  • 21mm ZM Biogon 2.8;
  • 75mm Summarit-M;
  • 73mm Sonnetar;
  • 75mm f/1.5 Nokton;
  • 90mm Elmarit-M; or
  • 105mm f/2.5 Nikkor (which I have but painfully slow to focus)
Something else outside the 35-50mm range? Only catch is that it has to be silver.
Dante
I wish I didnt buy any of my Leica and M mount lenses in chrome/silver.
I think they look great on my silver bodies but not on my black bodies.
Whereas my black lenses look great on both.
I've started to really enjoy chrome lenses on black bodies and am currently using a 35mm Summicron ASPH in silver on my black chrome M262.
In any event, I used to struggle with getting used to this practice, so I understand where you're coming from.
As far as silver lenses to add, I'd highly highly recommend the 90mm Elmarit-M if you can find one in chrome. If not that, the 90mm Summicron Pre-ASPH is beautiful in chrome, but big. I have both lenses, but my Elmarit-M is in black. If I had to choose one, I'd go with the Elmarit-M over the Summicron just from the perspective of size/weight. Sharpness and rendering on the Elmarit is amazing, so in terms of quality, you won't be disappointed. It'll also be very close in ergonomics to your Hexanon 90mm. Maybe that's a good thing, maybe not, but it'll at least be familiar.
Hello Dante,
My feeling has been for many years now that you cannot have and use too many 50mm lenses. The "rest" can be handled with one lens in the other focal lengths.
How about a Zeiss 5cm 1.5 or 2.0 from the 1930's in chrome?
I owned a silver 90mm Elmarit-M and esthetically and optically (IMO) it is a beautiful lens. You should be cautioned that it's one of the chromed brass Leica lenses and as such there is a hefty weight premium over the black version...too much for me in the end.
You could also consider the Zm 85/4 in silver.
Hello Dante,
Ha! At one point, I had every variation of the Zeiss: prewar 1.5 and 2, Opton f/2 and f/1.5. And both Nikkors. And the C-Sonnar. And the Sonnetar. Problem is that they all shoot almost identically. I ended up keeping the C-Sonnar because its front end does not rotate and the Sonnetar because it is very fast.
I think my record was having 14 50mm lenses at one point. You probably have that beaten, right? 🙂
D
For a longer portrait lens, I'm really enjoying the 73mm Sonnetar. It's much more functional as a general-purpose lens than the 50 Sonnetar (my 73 focuses accurately at all distances and apertures, without having touched the coma ring), but the images still have enough of that signature Miyazaki weirdness that you either love or hate.
If you pick one up, I highly recommend getting a JJC LH-JX70 kit to go along with it. Originally for the Fuji X70, this gives you an adapter for 49mm filters in the correct direction, as well as a functional hood that sits cleanly overtop. Plus the silver chrome version matches it exactly!
In your case, you seem to be thinking of getting a 75mm lens. I have a (black) 75/1.4 Summilux, but you want a silver one. Then I have a Canon 85/1.5 silver (ltm) that you may actually enjoy using with an M240. It is the old look.
I may have more than 14 50mm lenses, Dante, but I am trying to add only lenses that are somehow unique and different from what I already have and use. I added the Hologon 16/8 in M mount. I may add a "Made in China" Summicron v1 35/2 replica (in bronze). Not many are around!
I am tempted to get the new 75mm f1.5 Nokton. https://phillipreeve.net/blog/review-voigtlander-75mm-f1-5-vm/
It seems to perform very well and in the classic looks department it is a super model. And in chrome - wow, a super, super model! I presently own the 75mm f1.8 and though I like it, especially its "classic" portrait rendering, its physical length is a bit too long on an M camera to be quite comfortable (or look altogether good). I like the shorter more "squat" profile of the new lens - paradoxically, given I just described it as a super model.
PS I too will often find myself choosing lenses that LOOK good and perform well, over those that perform well but look less attractive. Deep down - I'm shallow
Ok. Will keep that hood unit in mind. Was the issue with the 50/1.1 just that it had to be dialed in? I've had phenomenal luck with mine, but it definitely has some quirks.
D
Dear Dante,
I have both silver and black Leica M cameras. One lens I would never be without, and always have it along, is my chrome 35mm f/2.8 summaron. I highly recommend it to anyone who likes silver chrome lenses!
Voigtlander 75mm f1.5
So glad I got rid of the 75mm frame lines in all my M kameras. Makes the view much cleaner, as well as the fact I find 75mm too close to 50 and so much prefer using a 90mm lens.
That CV 75 lens styling is "interesting". Looks like a bunch of different diameter tubes thrown together, almost as if it is meant to be collapsible.
After experienced shooters use all the Leica M focal lengths, most begin to to realize all focal M lengths have own uses, advantages, and disadvantages.
The 75 frameline was introduced with the 75/1.4 only after Leica M users had long requested a M 75 lens. Leica did not add a 75 frameline just to add another frameline. Any M frameline - if you don't use that focal length, its useless for you. That doesn't make one frameline choice better than another.
Compared to 90 M lenses, M 75's can offer some advantages
1) for the same aperture, a 75 is smaller and lighter
2) a fast 90 1.4 would be much larger and heavier than a 75 1.4
3) A fast 75 is superior to a fast 90 shooting in a crowded room that won't allow the photog to back up for proper 90 framing.
The Voigtlander 75/1.5 in particular is small and lightweight for a 1.5 lens, while also have a very quick throw from close up to infinity. Its a particularly nice handling lens with outstanding performance.
"Good Looking" lenses are like "Good Looking" cars, everyone has different ideas and preferences. Personally I like lenses that don't boringly look like other lenses.
- Nah, you don't need another one.
21mm ZM Biogon 2.8;
- You already have a nice 21mm!
75mm Summarit-M;
- I'm not keen on the looks of the black rubber focusing ring, but I'm extremely superficial.
73mm Sonnetar;
- You like weird lenses, so this looks good.
75mm f/1.5 Nokton;
- Same.
90mm Elmarit-M;
- I don't get why the front name ring is silver instead of black. One too many beers at the design studio that day?
- True.
Here's my list of suggestions:
50mm f/2.5 Voigtlander Color Skopar
- It has a nice hood, and it looks good.
90mm f/3.5 Voigtlander Apo Lanthar
- It has colorful rings on the nose!
35mm f/1.4 Voigtlander Nokton Classic limited edition for Map Camera
- There are only 250 of them.
28mm f/2.8 Canon LTM
- They should make more of these! The Ricoh 28mm is nice, too.
16mm f/8 Carl Zeiss Hologon, converted
- Too cool.
  • 75mm Summarit-M;
  • 73mm Sonnetar;
Dante
I am not sure, and I am glad you recognize the medical aspect of all this. But to be practical, much as I love the silver lenses, and even enjoy the apparent perversity of using them on my one black camera, I do like the lightness of the black lenses. I would not go for the heft of the Elmarit M 90 in silver, but instead the f4 Macro Elmar first version. I have that and it balances nicely on the M9-P - and looks the part.
Dear Dante,
It's pretty. I have a 35/2 Hexanon in silver, which is pretty hard to put down!
Dante
