Shipping my M3 internationally -- hints, anyone?
Justin Viiret
11:57 AM
Sydney, Australia
Hi there,
I'm a bit of a lurker, I'm sorry, but I'm trying to participate more nowadays. 🙂 Hello, everyone.
I'm after some advice; my M3 is behaving erratically at the moment. Sometimes the shutter doesn't fire, while at other times it will, but it stutters a bit and fires half a second or so after I press the release. And then (like all mechanical problems like this!) the problem disappears and the camera works fine for a roll or two.
It's driving me up the wall. 🙂 Two camera techs, both good friends and both with considerable Leica expertise, have looked at it and were unable to fix the fault completely (though it disappeared for a while). So, now it's going to DAG to see if he can work his magic and convince the camera that it's Ok to fire reliably every time.
My question: how do you all pack cameras for sending overseas? This M's travelling from Sydney, Australia to Oregon, WI in the States, and I'm a little worried about sending it. I'm sending it by insured courier, and so far I'm planning to wrap it in a hell of a lot of bubble wrap, box it, then wrap and box it again. Any pointers from those with well-travelled cameras?
My usual method -
Camera body (capped) wrapped & taped in a double layer of bubble wrap, sitting in a bed of polystyrene chips, in a goodly sized robust carton such that the camera is protected from transmitted shock from any angle. I've sent a couple of SLRs from KL to the States this way, without incident
Insured shipping, plus a customs declaration that it's a used camera body, defective, for repair & return.
Here's to getting your M3 back up to spec..
David
bubble wrap and styro peanuts, works great, make sure the box is large enough to give enough space in case it gets crushed a bit
Justin, I think the best method is to send the camera to me.. I live only 2 hours away from DAG.. or better yet, send both your M3 and your DR Summicron.. that way I can use the lens while your camera gets worked on 😉
but seriously, the double-box method is fine.. you don't need to worry so much about how it's packaged to get to Don.. after all, he'll fix whatever happens to it enroute, right? 😀
Thanks, guys. 🙂 Much appreciated, makes me a little less apprehensive about the whole process. I'll be shipping it off this afternoon, hopefully!
Keeping the DR so I can look wistfully through it on days with good light, Brett, otherwise I'd take you up on your offer. 😉
Well, it went off this morning (with Australia Post's ECI service) and should arrive in Oregon next Thursday. Double boxed and massively bubblewrapped, and I think things should be fine. 🙂
Hopefully Don will be able to do something to help it once it arrives!
