Show off your Light Meter!
Krosya
Konicaze
2:13 AM
I know - many of us use built-in camera meters, but since there are lots of people here that still use vintage cameras that either dont have built-in meters or they are not working correctly - I'm sure hand held light meter is something that you own and use.
Since, like many of us stuck home for the time being, I was going over my photo equipment and realized that I have more meters that I thought I did. Some I do use of regular basis, but some were just sitting in some camera bags or shelves. Many of the came with in a bundle that came with either a camera or a lens I wanted to buy and so they stacked up. So, it made me wonder if some people here also have a collection of light meters that they ended up for one reason or another.
Anyway - if you have just one, or a box full - show them off - maybe even comment which is your favorite and why.
Here is where I am at this point:
All work too (some needed a bit of cleaning or fixing) and seem to be pretty accurate (at least in a daylight for those selenium ones)
I have an "ancient " luna pro like similar to yours on the right. However, it shows the EV and has incorporated the Zone system. It works, sort of. What batteries do you have in yours and does it work?
Lots of very interesting meters there. My favorite meter is the Sekonic L308s..basically because it's new and works. However, I have a Gossen digisix flash....which is really small and will mount in the accessory shoe of my barnacks...if needed.
got the Luna-lux SBC w/fiber probe
the Minolta spotmeter F (spot w/flash and ambient)
my Weston Master V just died
Leicameter MR on or off the M2
also a Sinarsix w/45/57/810 inserts
The Norwood was my film school meter, from the early 70s. I bought the Sekonic a couple of years back, not because the Norwood no longer works, but because I can no longer read the Norwood's dial numbers (grumble, grumble).
I seem to have the same Gozzen Luna-Pro as "Krosya" (see my photo above), the model requires 2x PX13 mercury batteries. I am using 2x SR43 and 2x MR-9 Adapters. Works like a charm ; )
Luna Pro SBC - Great meter.
Pro -- Good in low light, incident and reflected, easy to find 9v battery.
Con -- It's big!
So mine came with a sleeve in the battery compartment to use something like SR44 batteries...which I tried and did not work. Then I bought Varta PX25A batteries, removed the sleeve, installed ....and it worked..for a while.
Do you know what the spring loaded battery switch on the back does?
+1 on Luna Pro SBC
more Pros: cheap, long-lasting 9V batteries / awesome 1 degree spot meter attachment / dials for filter factors etc., and still have the +2 / -2 range for Zone System
another Con: with the spot attachment it is HUUUUGE
I don't think I need to post iPhone picture here. This is what I often use with my vintage. I'm also vintage enough with my S16 meter for vintage and M4-2.
(avatar, on the left.) :)
My favorites are the Sekonic L-308S, Pentax Digital Spotmeter, and the Luna Pro. The little green Sekonic I've had since the early 1970's and it still works (Selenium). The Weston Master II is just as broken and worthless as the day I got it. I hate them.
Hap, it's for checking battery voltage ok
that's what I thought but worked intermittently and did not shift the needle to the mark.
I took the Varta batteries out , put the sleeve back in, as there is a diagram painted on the back side of meter...showing it in place with two silver oxide batteries. (SR44) That's what I used when taking possession of the meter, but it did not work. Just for fun, i put 2 new SR43 in the sleeve...and kind of jimmied around with the range selectors and all of a sudden it worked. Battery tester too. My guess is that it will peter out. So later I will try again . Since I have 3 other meters to test it against, I have found out that it appears accurate...enough. I bought it expressly for low light sensitivity feature. Not for Zone system or it's "convenient size".
Con -- It's big!
Mine is as big, yes. I see you have a null display version. I happen to like reading the EV. Once you get a good feel for EV you can pretty much guess most exposures, adjusting from ASA 100 to whatever ISO you are using.
I suppose there are advantages of each or Gossen would not have produced.
Nice impressive collections here, should take picture of my smaller sampling.
Though it does remind me of the saying, “Man with one watch always knows the time, man with two watches never sure.”
