Shutter not working/metering strange???
tom_patrick
11:04 AM
Hi
Just received my 35CC today. Its gorgeous I didn't expect it to be so beautiful!
BUT - the metering seems strange...
There is only a very small space between not being not depressed and releasing the shutter that meters. And the space it meters is different for over and under exposed.
For example, if a shot is overexposed I have to press the shutter around 1/4 down and even then it is a very small flash of a red arrow. Its like i have to 'find' it. Then when i underexpose, i have to press down about 3/4, and this is easier to see and 'find'.
What's more, to release the shutter to make an exposure i have to push right to the bottom, and press in, which makes it difficult to keep the camera still.
Is this normal? It doesn't seem to be from what i have read, and after using cheaper and far less quality RFs it seems a little strange??
Thanks for any help!
The meter lights on the Yashica Electros are often a little flickery, and sometimes you can even hear a buzzing sound when they come on, but this doesn't usually interfere with the operation of the shutter. As for the shutter button issue, that is a little strange, but normally the button has to be nearly fully depressed for the shutter to trip. If the camera hasn't been used much, try dry firing it a bit to loosen things up.
