Sigma dp Quattro vertical strap lugs
shawn
1:02 AM
The dp Quattro with the LCD viewer does not hang well from the strap lugs.
I used my Dremel to put a little recess on both sides of the LCD bracket to add another strap lug position. The camera hangs dramatically better this way.
Shawn
Thanks, I'm sure it will be much better. My DP1 had a Ricoh GW-4 adapter on it so it could switch between 28mm and 21mm FOV and the stock strap lug positions were a disaster with the LCD panel on it.
