Sigma Foveon full frame L-mount camera in 2019
lynnb
7:49 PM
Sigma has announced (DPReview's Photokina 2018 news) it will release a full frame Foveon sensor model in 2019 in the new Leica-Panasonic-Sigma L-mount (discussed elsewhere in this thread). Native Sigma L-mount lenses (as yet unspecified) will be released at the same time.
Sigma will also produce a Canon EF to L-mount adapter.
Looks like the wishes of quite a few on this Forum are about to be granted - Leica lenses on a full frame Foveon sensor.
Edit: from the same article, "Sigma CEO Kazuto Yamaki... said the company would not create any more cameras using its proprietary SA mount. However, existing SA-mount users will not be left out in the cold: the company will be able to convert some SA mount lenses to L mount. Those who want to retain SA compatibility will alternatively be able to use an SA-L mount adapter."
It will be interesting to see if they implement auto-crop modes to APS-c and APS-h, as many of the newer lenses for the SD Quattro cameras, such as the 30mm f1.4, wll not cover a full-frame sensor.
I've stopped buying digital cameras for a few years now and concentrating on mainly film photography again... This would tempt me back to the dark side.
I hope their software engineers are up for the task. I must admit I'm unfamiliar with the latest offerings, but using large format would have been faster than using a Merrill.
The only problem with the Foveon sensor for me has been the processing... In that you can only use their software... which of course sucks... Unless you like using crappy software then cool otherwise... Its a no go for me.
Haven't bought new camera gear since the release of the X-Pro1. This is all I ever wished for.
I should be clear I meant in camera processing and RAW conversion at the computer. Slow+slow= welcoming an Xpro1 to the family. :D
Forgot to mention battery life!
I'll be very interested in this too. Loved Foveon results for a long time, but whether I finally bite will depend on ergos and other "intangible" tangibles of the final product.
Once you do basic adjustments you can send it to your preferred software as a tiff file or whatever file you choose. No drama.
Never understood the "it's too slow" crowd. It is like they have to hurry upstairs to waiting naked partner, or else.
Once instant coffee was invented the world started its decline. :)
That actually hasn't been the case for awhile. The Merrill cameras can be processed in Iridient Developer and the sd Quattros can shoot in DNG so you can bypass SPP completely.
Shawn
It's great but...how many batteries?
sd Quattros have *dramatically* improved battery life compared to the DPMs. One battery was good for several hundred shots and I feel like life was comparable to Fuji's. The add on grip for the Quattro added 2 more batteries so it could go a long time.
Shawn
sd Quattro's were much improved in that regard. AF was still on the slower side but the general operation of the camera never really got in the way like the Merrill's did. For example, RAW writes were about half the time, 7 shot buffer and the camera could be writing out of the buffer while continuing to shoot. The Merrills reset the buffer write if you took a shot while that was going on.
I timed the sd Q H at around 6 fps in continuous mode. EVF was totally blacked out in continuous mode though.
A sd Quattro type body with a short flange distance mount would be a very interesting camera....
Shawn
The sd Quattro H already does this with DC mount lenses, and it can be turned off. The L mount support this so it would be surprising if they didn't.
Shawn
Shawn
Good to hear. Their use of DNG would simplify things.
