Silicon blue cells
DaveP
1:23 AM
Looks like Im going to have to replace the cds cell in my Petri Color 35. Can I upgrade to a sbc cell? Do they use a different circuit? I cant seem to find any info on the net. Has anyone upgraded an old metering system with one? It would be neat to have a more accurate sensor, if it will work.
The cells are very different. The CDS cells are resistive elements; SBC's are diodes. Radio Shack and many other places sell CDS cells. I have come across some that are close to what some of my cameras use in their "pot Luck" box of CDS cells.
Radio Shack also sells a book on the different circuits for CDS cells, photo-diodes, and other electronic circuits. Well written and easy to understand.
Brian:
I think I have a fundamental understanding of how CdS cells work, but I have never read a good explanation of Silion Blue cells. Can you give a thumbnail sketch of how they differ from Cds circuits?
I have a several Chinon SLR's with siicon cells, are there any rangefinders that use them?
-Paul
My "two Cent" explanation: A Photodiode is a solid-state device that produces a small electric current when struck by light. It is a photo-voltaic device. It is used in one of two modes: 1) the electric current is amplified to make a measurement, 2) the electric current is used against a bias current (stop it from flowing) to make a measurement. (I may revise my wording after lunch). Most photodiodes are based on Silicon, which responds from UV into near infrared. The "Blue" is a filter to get rid of Infrared response outside of what film would respond to.
Gallium-Arsenide (GaAS) Photodiodes were used in the Pentax MX and Nikon FM to solve the IR response problem without giving up sensitivity (IR cutoff). Indium-Gallium-Arsenide (InGaAS) is used to get a deeper IR response, and is used in IR motion detectors.
CdS cells have a spectral response similar but not equal to human eyes and films, so they do not require almost any filtering but UV. They are used as a current limiting resistor in series with a moving coil meter (another resistors group is used to adjust ISO setting). Then, light intensity rises, cell´s resistance decreases and current rises to a value measureable by the meter. Silicon diodes (any type) require some more complicated electronics. Usually they are driven with constant current so they are biased a little beyond the conduction voltage where the response (light vs. current flowing) is more linear. The voltage developed is either amplified, scaled and later displayed in analog or digital format. Filtering is mandatory as they (as Brian said) respond from UV to IR, and linearizing their response curve is a bit tricky.
All this electronics require a power supply of at least 3 V (usually 6 V) which, together with the full redesign of the metering circuit, turns the modification of the camera into something very complicated not allways worth the time and expense, and sometimes impossible.
I think that replacing the original cells with some new will be an easier, faster and much cheaper solution.
