haagen_dazs
hi (not sure what other forum to put this in)
i really need some help of simpleviwer. really desperate here..........
I would like to make multiple galleries.
that would mean multiple HMTL files
and each html file would have its RESPECTIVE XML file
the XML that was provided is called imageData.xml
after hours of coding and reverse engineering (literally)
i seem to be having major problems getting the viewer.SWF file to correctly read the XML file for the right information.
there is an important (i believe) code that dreamweaver doesnt insert into my HTML file
i added it
<param value="xmlDataPath=/galleryXML/praise.xml" name="FlashVars">
all images are in /TEST/images
all thumbs are in /TEST/thumbs
all html files are in /TEST/galleryHTML (which contains praise.xml)
all xml file are in /TEST/galleryXML (which contains praise.html)
in my XML file, this is the main part.
<?xml version="1.0" encoding="UTF-8"?>
<SIMPLEVIEWER_DATA maxImageDimension="1000" textColor="0xFF0000" frameColor="0xFFFFFF" bgColor="0x333333"
frameWidth="3" stagePadding="5" thumbnailColumns="3" thumbnailRows="3" navPosition="right" navDirection="LTR"
title="Example Title" imagePath="../images/" thumbPath="../thumbs/">
BASCIALLY : the thing isnt working.
PLEASE if you know coding and stuff like that please help me?
if possible, please email me at
mpang@umich.edu
because its going to be easier...
thanks alot!
Mark
i added it
mpang@umich.edu
thanks alot!
Mark
