Single tray processing and test strips.
megido
3:30 AM
Due to lack of space and the need to print larger than usual I'm thinking about the possibilities of single tray processing for 12x16 up.
However, it seems like a laborious way to process test strips.
Any insights or workarounds would be much appreciated.
Have you considered stacking the trays, like on a ladder? I would try something like that rather than single tray, which as you said, is a real PITA for test strips.
I tried this method but found that moving the (fibre) paper between trays was precarious to say the least.
I'm also looking to fix twice and tone so the tray count would become rather high.
Yes, I guess I could make more than one test strip in smaller trays to adjudicate exposure in the most critical areas.
Try this idea from my video: 3-drawer plastic storage bins. Use several next to each other for six trays. You might be able to find these drawers large enough for your desire print size.
~Joe
<iframe width="560" height="315" src="https://www.youtube.com/embed/LC0-NRU3oZ4" frameborder="0" allowfullscreen></iframe>
I used stacked trays for several years back when I lived in apartments and lacked space. I found it worked well, even with fiber based papers, though I was using only 11x14" trays.
I did find that using a stacking frame that was open on the long side of the tray, rather than the short side, and allowed the trays to stair-step a bit proved to work the best.
Nova slot processors are a good option when space is limited, they are also very good for doing RA4 development due to heating elements that keep the chemicals at the correct temperature.
I'm not sure of there availability in North America, there's usually a few on eBay in the UK.
I have made my teststrips in small trays/Nova slot and made the larger prints in one big tray. As you would with film but a bit more messy. I also have old Jobo cylinders with DIY rollers that take 60x50 but actually enjoy the one tray system more.
