pagpow
I've just been leafing through Lee Frost's Panoramic Photography and Arnaud Frich's book of the same name.
Should I conclude from their shots and this earlier thread of ours
http://www.rangefinderforum.com/forums/showthread.php?t=55653
that if I want unbanded transparencies, I should suck it up and buy an XPan or a Noblex? (in 35mm)
Has anyone here had any luck with consistently unbanded transparencies in either Widelux or Horizon 202?
And does the Noblex consistently avoid banding?
Thanks.
Thanks.
sepiareverb
genius and moron
You can't go wrong with an XPAN. Lovely chromes out of that thing every time.
Tuolumne
I shoot a Noblex and Xpan. Both great cameras, but I really love the huge negative (chrome) you get with the Noblex. What banding are you referring to? Both cameras shoot a full panrama on a single strip of film.
/T
/T
lZr
L&M
Horizon S3 Pro shots
Velvia 100
http://www.rangefinderforum.com/photopost/showphoto.php?photo=52319&ppuser=2130
Sensia 100
http://www.rangefinderforum.com/photopost/showphoto.php?photo=56233&ppuser=2130
Fuji Astia
http://www.rangefinderforum.com/photopost/showphoto.php?photo=75669&ppuser=2130
Fuji Provia
http://www.rangefinderforum.com/photopost/showphoto.php?photo=78094&ppuser=2130
Velvia 100
Sensia 100
Fuji Astia
Fuji Provia
pagpow
Thanks, Tuolemne, the banding I was referring to was not on the Noblex, but on the Widelux and, less pronounced, on the Horizon 202 -- vertical stripes of different density due to exposure variations as the lens wipes across the film.
Tuolumne said:I shoot a Noblex and Xpan. Both great cameras, but I really love the huge negative (chrome) you get with the Noblex. What banding are you referring to? Both cameras shoot a full panrama on a single strip of film.
/T
Tuolumne
pagpow said:Thanks, Tuolemne, the banding I was referring to was not on the Noblex, but on the Widelux and, less pronounced, on the Horizon 202 -- vertical stripes of different density due to exposure variations as the lens wipes across the film.
Ok, got it. I have never had a problem with my MF Noblex. Great and consistent panos in color and B&W.
/T
pagpow
Lazar, great shots, thanks.
Do you do anything to avoid the banding or is your S3 simply blessed?
Does anyone experience different behavior by shutter speed?
lZr said:Horizon S3 Pro shots
Velvia 100
Sensia 100
Fuji Astia
Fuji Provia
lZr
L&M
Thanks pagpow. Yes, sometimes I use the Clone tool in PS. Usually the verticals are seen in the sky, and sometime down to the ground. The vertical are reasoned by the sunlight reflecting from the slit. Most of the time I must be at least 90 degree to the sun to be sure the result is missing any verticals, but you know...
