Slightly frustrated...
Lauffray
Invisible Cities
6:20 AM
Hello all...
I have only one system I use all the time and so far I've been very happy with it (M7 + 35 cron asph)
Until one day while on vacation 6000km away from home, I had a nasty accident and was left basically with no working camera. So, after coming home and repairing it, I've decided to try and put together a less expensive backup system, an old-ish full mechanical rangefinder and a compact 35/2 lens.
After quite a bit of research online, I'm now basically facing two equally unattractive options, either an affordable, new-ish, slower 35mm (Zeiss 35/2.8 or Leica 35/2.5) or an older, expensive, faster one (typically Leica crons) with prices averaging 1500$ at least
Argh..... !!! I feel like I'm turning in circles with no decision in sight
What is so unattractive about having to settle on a great lens as your back up?
Wow, you must rethink what unattractive really is... don't be too spoiled to enjoy quality equipment.
you could get a leica cl + 40mm summicron or minolta CLE + m-rokkor for under $1000. close enough to a 35/2 for a backup.
I just feel there's too much compromise, the affordable option is too slow (I often shoot in low light, even f/2 is rarely enough) and the faster option is just way too expensive
I'd suggest a Bessa R2M and the Voigtlander Nokton 35/1.4.
If that's not good enough for you as a backup kit then the dilemma you're having is nothing to do with the available equipment.
Go with an M2/M4 and get a 35mm or 40mm Nokton. I'm sure that will be good enough for a backup system.
I use a Leica IIIc with various 50/2 collapsable lenses, plus a 35/3.5 summaron.
Thing is, there weren't many fast & wide options back in the day... So use a 50 for low light, and the 35 in good light. What's not to like?
The Nokton 40mm SC, razor sharp and the single coat was made for B&W, a M2/3 as a back up body.with Also think the VC 35 1.7 could be an option. Tuna is a magician with it.
Why don't you have your back up with a 50mm lens and can use back up when 50mm is more suitable and not just wait for next calamity? Retina IIIc with 50/2 is a cheap, tiny but superb back up. If I killed my M6 I would be happy with Retina until it returned.
Lots of good ideas here, thanks folks.
I do have a 50mm that I rarely use, ever since I got the 35mm It's been on 99% of the time
I don't see why this is such a big deal. I totally support suggestions of M2 + Nokton 35/1.4. I'll also suggest either M4-2 or M4-P with that same lens. Problem solved. And all very affordable.
I have great trouble trying to think up a definition of "unattractive" that matches what seems to be yours when it comes to 35mm lenses.
Just get any of the Voigtländers already, 35/f1.7, 35/f1.4, 40/f1.4, or the outstanding 35/f1.2 if you can scrounge up the extra money, or a 35/f2.5 if it really has to be cheap.
If you don't mind used lenses, there is a Canon 35/f1.8 for 315 EUR Buy-it-now on eBay.
