Small Meter Suggestiions for 2017
roscoetuff
8:48 AM
I've got a Sekonic 758 big, honking big-as-your-camera light meter that gives good service, but it's time to look for something a little more pocket-like where 1) battery drain ain't a problem, 2) pocket size, 3) reliable incident light meter, and 4) accurate...and 5) even might help with Zone system.
Camera has a reflected light meter and it works pretty decently. Looking for a complement - so don't need all the bells and whistles the big guy offers (758). Thanks!
Sekonick 208 with MANDATORY enhanchement shown on this Photo.net thread
The LV values enhancement make this little unit super fast to use.
Bonus points: attach it to a retractable laniard to clip on camera strap or belt loop.
The Sekonic L208 is a lovely little reflected light meter, but isn't all that great when used in incident mode. The incident integrating dome is rather small and doesn't give the most accurate results. I have one, I use it in reflected mode exclusively. $125...
Other possibles:
The Gossen Digisix 2 has a much larger incident integrating dome and produces significantly better readings. $173 at B&H.
The Sekonic L398A is a superb, old-style meter with a superb incident integrating dome on a big swivel, no batteries, etc. I have the older, L398 model. It's a little limited on bottom end sensitivity but is a cracker for accurate results. $210 new... I bought mine used for $50 or so from Ebay, IIRC.
G
I use the same combo: L758 and L208. Rarely use reflective metering and no complaints, even when using slides.
Many review I read indicated that the digisix is a battery hog. However, I have no first hand knowledge (because said reviews scared me away). It would be good to hear if RFF members had positive experiences with battery life, which is of primary importance to the OP.
Gossen Digisix or Digiflash. No need for a hack, you press a button and see the measured EV value in the LCD display. Turn the white wheel so the matching EV value appears in the small window above, and you see all the f-stop/time combinations. Super easy, super accurate, a thing of beauty!
Gossen has been building light meters for 100 years now, and I think they are the best in the business in terms of accuracy, build quality and user interface. They are the Leicas of the light meters! :D
Why do you need too clutter up the meter area when the EV is clearly visible on the dial?
To see the EV in the window, you'll have to move the dial. The hack will skip that process. Push the button, and the needle will point at the EV right there and then.
I don't always use a light meter, but when I do, I use 208. (tho I don't have that mod)
The dial is set by manually matching the green needle with the red one (the measurement).
I guess a power user might only need the EV value and hence benefit from not having to rotate the dial.
I also have a 208 but without the mod.
Thanks! You guys are amazing. Going to give the Gossen a shot. Sekonic's been a mainstay in my life for 44 years, but the bigger dome... and it's all about the dome for me, makes it worth a shot. Simple. Small. We'll see. WHEN I use a light meter... like Anders, I don't always... I like to have it handy on a belt, 'round my neck or somewhere easy. If it measures up, it'll be a keeper. Crossing my fingers it's not cheesy.
It's worth noting that the Sekonic L-308 also can do EV readings. It can't show you aperture/shutter speed readings at the same time, but for those who have the table memorized, it's just as good as the Gossen. It can also do third stops, in case you want more precise readings for half/third stops on apertures.
I think either the Gossen Digisix or Sekonic L-308 are definitely the best in their form factor. Older folk who are more familiar with EV will likely prefer the former, while younger individuals will tend towards the latter for its familiar handling. I don't think you can go wrong with either, it's merely preference.
Slowhanded: Thanks! Given I've got 2 Sekonics (my original "Studio Deluxe" from the 1970's and 1-year-old 758), my decision to go for the Gossen Digiflash was based on size... and trying a Gossen as a brand I've known almost as far back as the 1st Sekonic. Sekonics are trusty friends, Gossens like folks "across the bar", and Weston's "the dear departed". To paraphrase MacArthur, "Old Light Meters never die, and they don't (even) fade out."
Gee, just get a nice little Gossen Pilot -- selenium, yes, but very accurate, I've found, and it has a built-in "roller blind" for incident work. Very inexpensive and pocketable.
light meters
light meters
I've had good luck with Gossen over the years. The one I have looks like what is currently called Gossen Sixtomat. While not small nor large, its form factor is about like a cell phone. Speaking of which, app Pocket Lightmeter has worked well for me, and even measures white balance/color temp.
I was with a friend who wanted to buy a new meter, and at a reputable camera store, the salesman wouldn't sell him one, insisting that the app did as good a job.
