Small waist bag for 2 Fuji lenses
twopointeight
8:21 AM
I'm looking for a waist bag to fit 2 small lenses, specifically the Fuji 50mm and 23mm. The 35mm will remain on the XT2 body most of the time, switching to the 23 or 50 when needed. I keep the body and lens on an Artist and Artisan adjustable sling strap so don't want a shoulder bag, backpack or sling bag interfering. Appreciate any suggestions.
Maybe the mini quick pack or quick pack from Topo designs? I have the quick pack and use it for 2 M-bodies with small lenses attached. in my case, I have an M262+35 summicron and an M8+28mm Elmarit-m
Both would probably be great for your needs with the mini being smaller of course.
https://topodesigns.com
https://www.youtube.com/watch?v=fMdjPfBTIIc
Lowepro has a small waist bag, the Trekker. I'm not crazy about the metal hook fastener, but it also has a zipper for secure closing.
Another option is a small Domke bag, the strap comes off, then you use the provided belt loop.
I have a "Hakuba Shell"
SP-QA01MCMRD - shell QA01 Movie Case Medium ReD
It's a video camera bag but the x100t fits perfectly so a couple x-series lens should fit. The product comes with a removable shoulder strap and belt loops, but I just throw mine into my daypack.
Main specifications] Inner dimensions: W165 X H80 X D80mm
Outside dimensions: W180 X H95 X D95mm
Weight: approx. 120 g
Material: polyester
Accessories: shoulder strap
Price: Yen 1,880 (about USD 17.00)
https://global.rakuten.com/en/store...bpQ&siteID=je6NUbpObpQ-OB6AVRyWfdv6lusBnnn6yw
I use the Peak Design Range Pouch, medium. One lens on the camera and one in the Peak, along with SD cards and batteries. It will fit my 90mm with a short hood.
For those two small lenses it should work, but you might look at the large too
Thanks for all those good suggestions. I might go with the Domke, a bag I owned years ago until the zipper broke because I was cramming too much into the bag.
