So those new Zeiss ZM lenses...
leicaAngst
1:58 PM
...were touted at launch as being 'digital ready' with anti-reflective coatings on the rear surfaces of the barrel, and other things I forget.
So, do they work better than other non-digital lenses (like the Leica and Voigtlander equivalents), particularly at full aperture (which I understand is most 'legacy' lenses achilles heel)?
lA.
The Zeiss 18mm ZM is the only wide I have that can be used with confidence my E-P1.
While it's far better than my wide Leica lenses, it's not perfect - there is a little smear in the far corners. A 3:2 crop is enough to cure it.
However it seems to be by accident rather than design that it works reasonably - so it cannot be inferred the 21mm or 25mm will do the same.
some 100% crops from raw.
