Ash
Selflessly Self-involved
(updated 24th Sept)
Hey everyone.
I want to say a big thanks so far to all of you that have given me help on all the silly questions I've asked so far. But now I gotta ask some more! 😀
Some of you will know the Rolleiflex I'd bought and wanted to restore. It's a 1950's Rolleiflex 3.5 Automat (tessar), in dog-rough condition but it works 'fine'.
Here's my To-Do list, and what I gotta sort out somehow - some bits are sorted, I'll try and keep this list updated if I can. Definitely not in order of importance, more in order of "hey, I forgot about that!"
Also I'd like to state I have the 450 page service manual (in german?) and I'm finding it really difficult to understand, so it probably answers some of these questions I have, but I'm still getting my head around the document! I can't find the pages with the exact same model, all the 'flex cameras have different fronts I think
If you could link me to other bits and pieces (i've lost the original thread with some info on the painting cameras for example) please could you make sure you state which question you're answering? Thanks!!
I really appreciate all the help!!
Hey everyone.
- Dodgy Hood:
Broken bit of metal in there, won't close smoothly - half sorted, but magnifying mirror is still wonky.
Q: Anyone got some macro's of how this magnifier on hinge SHOULD look?
- Flaking paint and tarnish on latches:
Began sanding down some of the flaking paint, but waiting until I have the leather clean off the camera before I get it all off and repaint.
Q: Acrylic paint used for model airplanes is fine, right? Can I get away with typical acrylic from an artshop? Any difference other than price? Do I need to give it a lacquer finish or anything?
A: OIL BASED ENAMEL - thanks Frank S
Q: How can I repaint the front piece without losing the serial no. and DBP DBGM etc??
Q: Should I sand off the tarnish and get some brasso-esque stuff on it? think that'll do?
- Dim/Dirty focusing screen/mirror:
Replaced screen with fresnel I got from DReilly (thanks!)
Q:How the hell am I meant to get all those speckles out of the viewing mechanism? I know some is chipped paint, so will a compressed air can be good enough?
A: Get a new mirror from the bay - Victor M
- Replace Screws on Hood:
One of the screws from the hood no longer fits tight, it won't thread at all.
Q:Anyone got a surplus of these? They're the same size for all rolleiflex's and 'cords I think (one from my 'cord fitted fine, but that is far from a donor body!!!)
A: Don't worry, get them last. - VictorM
- Open/Close latch on bottom is a dodgy/tight fit:
It opens, it closes, it holds the back light-tight, but its a bit painful on the fingers when the metal won't easily open, and occasionally the latch female doesnt mate properly with the body's male point.
Q:Short of getting a new back to the camera, is there any way I can fix this?
A:This is normal on the cams, so just be careful
- The 'accidental exposure' latch is missing:
Someone must have snapped it off down the line - its the little sickle-shaped bit of metal that hooks under the shutter release to stop it firing (duh)
Q:Anyone got one laying around? Any idea of dimensions so I can mock-up a new one?
A:Get a new front piece
- Shutter problem:
I'm not sure if this is down to incorrect technique - I'm used to winding on, and then setting shutter speed. The little dial for setting speed is SO difficult to turn its like trying to move a fridge using one finger! I can just about rotate from the slowest speeds to 1/250, but unless I fire, set, THEN wind on, I can't physically get the 1/500 speed. I think the lube is all but crystalised! The speeds actually work fine, even the slow speeds snap open and shut at the correct timing, its all down to how impossible speed-selection is - I dont really want to pay for a full shutter CLA that may not even fix this problem (no guarantees and all that).
Q:Are there any UK (shutter) CLA people for Rollei's?
Q:Once I get the front leather off, will there be any points I can WD-40 and lube up to quick-fix this without needing a full CLA?
A:I've taken the front piece off and lubed up the gears with a tiny bit of bike oil. It seems fine for now 🙂
- Self-timer thing is broken:
I got zero idea about that side of things. There's a very unsettling TWANG!! when I trip the top right switch on the front of the camera, and it must have taken about 30 seconds zzzzz'ing before the photo was taken. I'm probably damaging the mechanism further so I'm leaving this well-alone. From the bottom right of the camera, the winder is missing - http://cgi.ebay.com/Rolleiflex-Auto...ssar-lens_W0QQitemZ180024768885QQcmdZViewItem (not affiliation) shows a tab, that no doubt rotates to set timer speed. I'm worried the cost of fixing this, and the shutter, will amount to the cost of buying another one of these cameras in excellent condition!
Q: Should I brush this under the carpet, or will it be possible (and not too expensive) to fix?
A: (half answer) The twang is normal. - so really, brush under the carpet 😀
- Camera needs new leather:
I'm waiting on Kim to get back to me about some leather, but I understand things are a bit busy for him right now.
