martin.mintal
Camera: Zorki4
Film: Kodak Portra 160NC (color shots)
Scanner: Epson V500
Unfortunately, my Gossen Lunasix 3 does not work as I thought it would - originally, it had a 1.5V battery, but because these are not available any more, I had to use a similar 1.35V (= sometimes a heavy underexposure). Therefore the C41 color negative shots are quite good (regarding the image quality) but most of the b/w images were very very noisy and dark....
I also had some difficulties with the additional viewfinder - I always forgot to compensate for the parralax correction and therefore, many of my images are badly composed (cut off heads or legs...)
01/ As you can see, my Jupiter 85mm can be quite a sharp lens (f2.8)
02/ Jupiter 85mm, f4 i think
03/ Jupiter 85mm again, f5.6
04/ Jupiter 85mm
05/ Jupiter 50mm
06/ Jupiter 85mm
07/ Jupiter 50mm
08/ Jupiter 50mm I think
09/ Jupiter 85mm, homeless man in Bratislava (I gave him 2EUR for his photograph 🙂
10/ Jupiter 50mm
Scanner: Epson V500
04/ Jupiter 85mm
05/ Jupiter 50mm
06/ Jupiter 85mm
07/ Jupiter 50mm
10/ Jupiter 50mm
