Alowisney
I wanted to see the difference in the ISO capabilities and image quality of the NEX-5 and NEX-5N, so I set up a tripod and shot a series of shots from each in RAW+JPEG to see the differences. I chose a scene in my house to show color reproduction and detail that also had some straight lines to also show distortion from the 18-55mm kit lens. I used Program mode and just adjusted the ISO. I left the lens at 18mm for each shot. You can check it out on my blog here
I hope this is helpful to someone!
uhoh7
I wanted to see the difference in the ISO capabilities and image quality of the NEX-5 and NEX-5N, so I set up a tripod and shot a series of shots from each in RAW+JPEG to see the differences. I chose a scene in my house to show color reproduction and detail that also had some straight lines to also show distortion from the 18-55mm kit lens. I used Program mode and just adjusted the ISO. I left the lens at 18mm for each shot. You can check it out on my blog here.
Link is dead.
What were your lenses and conclusions?
Alowisney
That's odd. If I go directly there it works, but from the forum link, it doesn't. You can just go directly to my blog at http://brianallengodfrey.blogspot.com/
I found that the NEX-5N's image quality and ISO ability really outclass the NEX-5. Also, the changes in the UI of adding more options for the customizable buttons really make it easier to use.
segedi
RFicianado
Maybe you can edit the original and make sure the http:// is in there.
segedi
RFicianado
And nice test by the way. The 5n is has some really impressive high ISO renderings.
Alowisney
Thanks!
I edited the original post to put in the link by hand and it seems to be working now.
