Sprocket Panos...
gdi
4:05 PM
I just tried using my Mamiya 7 without the pano mask to expose the entire width of the 35mm film. Here are a couple from the first roll. Suggestions for my next attempt welcome, as are other's samples...
This is cool! I've done it with my holga 120N and it was heaps of fun.
Scanning was very difficult! I had to make a special adapter thing and it was very tricky to keep the film off the glass and as flat as possible!
...on a side note that building looks a like a level on Call of Duty 4... huh...
I scanned on on CS 9000 using the 6x7 mask and no added masking. You can see the light bleed. That and the soft, unsupported edges in-camera work to allow the Mamiya system to approach Holga performance levels!
I tried COD 4 once and I still feel a little queasy 3 weeks later (motion sickness)!
haha. :)
I keep meaning to sit down and work out how many "clicks" it is exactly on the winder of the Holga between frames. I'd like to put in a 24 exp roll, and take a pano that extends the whole roll. One "seamless" photo. Maybe do it on slide film so you can just mount it on a window :rolleyes:... just some musing.
haha. :)
I scored a mark on my Holga's winder knob and turn it one and a quater turn per frame, this works fine for me.
I also have a Diana F+ with a 135 adaptor back, this device has a frame counter.
//Jan
