Strange results: Tri-X in Rodinal
dufffader
Leicanaut/Nikonaut...
8:37 PM
Seoul
Normally I would be using Tri-x 35mm rolls and develop it in Rodinal 1+50 and I find 14:00 at 20C to my liking.
Recently I moved to 100ft reels of Tri-X (400TX) loaded into IXMOO cassettes, and had 4 rolls of it shot over a 1 week period with a metered Leica M6 (for which exposures measurements are normally right on). During the same week I had 4 6 more rolls of different film and they were fine.
I developed these 4 rolls of reel Tri-X using my standard timing, but the results were less than pleasing. All 4 negatives came out very thick, darker than normal when held up to sight. It looks as thought it was overdeveloped. The sprocket areas were thick as well, and through troubleshooting, I ruled out issues with my fixer.
Most of the scans were useless. The ones that were close to fine tells me that it is at least 3 stops over and extremely grainy.
While I'm about to do tests to find out the issue, wondering if anyone has some idea what the issue is:
- Can it be that reel Tri-X have different development times? Its a fresh reel that is not past its expiry date. I would guess this is unlikely.
- I'm about to shoot a test roll with +3 to -3 stop exposure. Might also try and cut 4mins out of the development time, i.e. 10mins @ 20C Rodinal 1+50. Any other suggestions?
- If it was indeed overdevelopment the first time around, should I be seeing thick film around the sprockets as well (outside the areas normally exposed)?
Thanks. I plan to do the tests this weekend.
I'm amazed that you've been using Rodinal 1+50 for 14 mins at 20deg. I would never go over 10 mins personally and have discovered that 8 mins seem adequate a lot of the time. I've used Tr-X from a 100ft reel and boxed individual rolls and haven't noticed any difference in my results.
I get my best scans when the negatives are a little thin and usually subtract around twenty percent from the times recommended on the Digital Truth charts.
I'd suspect that some kind of radiation has fogged the film. X-rays perhaps? Maybe it was stored under high heat? My experience with bulk Tri-X shows it to be no different than factory loads.
that's strange. i've been alternating between bulk reel tri-x and factory loaded tri-x and they seem fine, no differences at all. i've been using rodinal 1:100 + ilfosol 1:100 stand development for about 25min at 25degC fix 6 minutes, film exposed at 400, no problems at all.
were the 4 rolls processed together in the same tank or separately?
could the whole reel have fogged?
A) The whole reel is fogged, or B) You fogged it while loading...
By the way, your times are close to mine: I rate it at 400 ASA (200 with yellow filter) for shadows or overcast scenes and develop it on Rodinal 1:50 20ºC for 18 minutes / every minute three inversions. For sunny scenes I rate it at 100 ASA (50 with yellow filter) and 14 minutes with three inversions every three minutes... (Incident metering)
Good luck with that reel!
Juan
Bad (hot) storage leaps out as the likeliest candidate. Have you had good results from any of the bulk-loaded rolls?
Mis-mixing the dev comes next. Or, as Adrian says, fog.
Cheers.
I'll see if my fresh test rolls are fine this weekend. I carried them for a week in hot weather, so that could put heat as an issue. The other rolls I had with me are Neopan 1600s, ERA 100, and assortment of colour negatives, and those were fine. IXMOO plus heat might be a no-no.
That is a clue that something other than developing is amiss, is it not? I wouldn't worry about using IXMOOs. Those have been around forever, with no complaints that I've found.
If I'm reading the original post correctly, only the bulk loaded rolls were affected. It sounds like you might have a light leak somewhere along the line in your loading process or in the cassettes themselves.
