Stuck aperture ring on LTM lens
mdwsta4
Matty Westside
2:13 AM
I just received a 5cm Summitar lens in overall good condition. Unfortunately, the aperture ring is extremely stiff; I cannot move it beyond f2.8 and even that is extremely forceful. Any suggestions on how to improve this without sending it off for a CLA?
Thanks!
M
If I read that post correctly, you collapse the lens, remove the two screws, then the aperture ring should unscrew, correct? From there you would clean the area with lighter fluid, re-grease, and reassemble. Is that right?
I was in your shoes with EXACTLY the same problem a few nights ago.
First, this lens is notorious for this -there is nothing wrong with your sample!
I ended up following two methods which I, personally, found easier to understand:
http://kameraking.blogspot.com/2012/10/summitar-5cm-sticky-aperture-repair.html
and
http://justinlow.com/articles/repair-leica-summitar
Night and day difference! Now the aperture ring is smooth as butter! Also went 1 step further and did the same for the focus ring. Unfortunately, I'm running into a problem with the distance. I am able to get to infinity, but it only gets as close as 4.5 feet. Been trying for the past hour to align it properly to no avail.
Sorry I could not reply ... was out all day on a glorious Sunday here!
Sounds like you got the ring sorted! I can't offer any particular advice on the focus.
