stuck self timer yashica GT
jorgef2002
10:26 AM
Hello rangefinderorum,I need someone's help, my Gt self timer is stuck it only moves 1/4 and the shutter does not open any help will be aptd thank you.
jorgef2002:bang:
jorgef2002:bang:
One thing you might try is to wind the selftimer and press the shutter button while gently pushing on the selftimer lever to help it through its travel
My latest gt had the same fault.you must take off the front off the lens and take out the selftimer then it will work again check yashicaguy site for instruction
Rule of thumb on Yashica and other cameras with lens mounted self times "don't use them and they will not get stuck"v:D
Mikael.n, thank you for your advice, I got the reply from Colyn before yours, see the advice,perfect it is done it works again,thank you for your advice too, regards.
jorgef2002
jorgef2002 said:
Colyn, thank you so much , it worked, thank you. And very nice pictures in your gallery.
jorgef2002
Glad you got it fixed. Many of these selftimers don't work properly because of lack of use so I prefer to use an external selftimer.
Thanks for the feedback on my gallery.
Hi everybody,
I've just had a look at this thread and would like to explain my issue with the selftimer... looking for help.
My Yashica GT has a selftimer that never worked, at least since I own it. I don't really need to use the selftimer too much, but if possible, I'd like to try to fix the problem.
Mine is not stuck: it moves "down" when pressed and comes back to its original position... Any idea/sugestion about what the problem is / how to solve it?
Thanks!!!
