Summaron 3.5 compare to Summaron 2.8
terrafirmanada
6:59 AM
Hartford, CT
First of all, I own the 3.5, and really like the images I have taken with it so far. But it does have some very slight haze. So, I am thimking about sending it to DAG for a CLA. The 2.8 seems to get more positive remarks, but this might be mostly due to older lense issues (fungus, cleaning marks, haze) in the 3.5.
I am wondering if any users have experience with both of these, and can comment on the optics, as well as other user impressions.
When I bought this lense I thought the 2.8 might be the more user friendly, but since I have other lenses with the 3.5 style tab, it felt very comfortable.
I do not really need more speed, so in that regard the 2.8 is not important.
I spent a great deal of time looking at flikr under Summaron- but that does not give you the distinction between models. However, you can tell by looking that it is a special lense.
So, if anyone has an opinion or images to compare, I would be interested in learning more.
Sorry, I have jsut the 3.5 Summaron, also with a bit of haze. I won't replace it, it's a keeper. I will eventually get it cleaned.
I have both the 2.8 and the 3.5. Although I haven't subjected them to a rigorous comparison, I am just as pleased with the 3.5 images as the 2.8. It took maybe an hour to get comfortable with the controls on the 3.5, but it's worth it. That tiny lens is wonderful! There are a few shots from the Summarons in my Gallery.
Richard
I use a 3.5 Summaron and am very pleased with the results.
I feel it gives photos a very classical look.
Thank you for your replies. I would also be interested in knowing how phototone disassembled and reassembled his lens. Anyone have pictures of this? If I were to do it I would need the visual first. Then is a bit of vinegar and water the cure? Is benzine a bad idea? Hmmm well I need to send my Summitar in since it has oil on it's blades. Perhaps I can get a two for one deal.
I took apart a collapsible 50 summicron LTM about 6 months ago. Like a noob I turned it upside down and all the blades fell out LOL.
So if you are gonna take it apart be really careful because those blades took me forever to get back in correctly.
I don't have a 35 cron though, so I can't help you in your comparison. I just thought I'd add some words of caution.
-Mitch
Haven't ever used the 2.8 or even seen it, but had a 3.5 from 1985 to 2002 and last year acquired another. Can't say if the 2.8 gives the almost three dimensional effect that the 3.5 does. My only grouse is that the whole thing rotates, which often makes focussed distance and aperture setting difficult to see and rules out the use of a rectangular hood without more fiddling than two hands can manage.
-Mitch
Yeah, the Summicron has "loose" blades that can be spilled when you take out (uscrew) the front lens block. Not easy to get back. (I know).
However the 35mm Summaron does not have this problem. It has been two years since I disassembled mine, so I can't give a blow-by-blow account as my memory is foggy. It is not easy, I do remember that. You need lens spanners, and other items. You need a suction cup lens element puller, etc. Best to clean elements with "lens cleaner", then use compressed air as you reassemble to blow away residiual dust that can collect as you place elements back in place.
I cannot confirm this for sure but believe it to be true. Someone else will no doubt comment.
I have been told that the 2.8 differs from the 3.5 summaron in much the same way that the 50mm f2.0 summicron differs from the summitar - i.e. it uses the more modern lanthanum glass which in the case of the sumamron allowed the formula to be pushed an extra stop and gives better rendition.
Having said his I have never used the 2.8 - only the 3.5. As far as that goes however I can say I am very happy with it - So much so that I actually own two of them: The earlier 36mm filter screw mount version and the slightly later version in bayonet mount taking the 39mm filter. Both are lovely lenses that I would hate to part with.
