Summaron 35mm 3.5 LTM with haze
Uglee
8:18 AM
I have a 1951 Summaron that I am trying to clean. I am having difficulty accessing the inner lens surfaces at the diaphragm. I can easily remove the front and rear lens elements, but I cannot see how to remove the inner lens block. Can the lens located behind the diaphragm be removed from this point or am I looking a a total tear down? I have not been successful in finding any tutorials or diagrams on line.
I called a local repair shop ( San Francisca area) and was quoited a minimum $300 for a cleaning. I would appreciate any guidance or insight regarding a DIY cleaning or reasonable cost professional repair. The lens is in otherwise excellent condition.
Thank you Vic. I see that Youxon's estimates are very reasonable. It is a bit ironic that I will be in his area this spring and had planned to use this lens on that trip.
Don't know if you've done anything yet but Youxin cleaned the internal haze from my LTM Summaron 3.5 last fall. Cost was $60 and it looks like new. Fantastic lens.
Youxin is known to have a turnaround that is pretty much same day, as far as the work is concerned. You could email him, start a dialogue, say you'll be in the Boston area and perhaps could drop off the lens for a day for him to work on. He's very accommodating and one of the nicest camera techs out there.
As for the repair itself, the later LTM f/3.5 Summaron is one of the easiest lenses to work on but I seem to remember not being able to clean a bit of the inside of one group, I think because of the issue you are mentioning. It's been a couple years since I've worked on one. I will also depend upon which LTM version you have as there are several.
Phil Forrest
Thank you Rdtaylor and Phil. I was about to contact Youxon but decided to take another look at the lens. This time I discovered that the inner lens groups are pressed in to the diaphragm block. I noticed a slight movement of the front group and was able to remove it using a very small suction cup. The inner lens surfaces cleaned up quite easily and the reassembly went smoothly. I recently used the lens on my IIIa and was pleasantly surprised with the resolution though the lens is still soft compared to my Zeiss or Cannon lenses.
I am relieved to know that we have someone as capable and reasonable as Youxon available to service our equipment. I am also very grateful that I have the members of this forum to to ask for help with their knowledge and advice when most needed. Thanks.
David Lee
