Summicron recoated by ARAX - looks good!
sockeyed
2:50 PM
Vancouver, BC
I sent the scuffed and mucky front element from my rigid 1957 Summicron-50 to ARAX in the Ukraine for a polish and a recoat. It took some time (around 10 weeks), but cost very little ($30 + shipping) and the results are great! My element is pristine and I'm very happy with the quality of the images. Here are some samples, shot on Efke-50 souped in Rodinal.
I'm sure that most of you will find these images very difficult to look at.
More images
More images
Here are three more images from the same lens, same day.
Efke-50 + Rodinal (1st)
Tri-X + HC-110 (other two)
Interesting shots! Not so hard to look at. I'm glad you are happy with the results. I often wondered how much the repolishing and recoating process would change the original lens formula.
I only took a couple of rolls with the lens in its original condition. It seems that the character is still there and that this lens has retained its vintage feel (noting that the lens was always sharp as well). It seems to flare less although it does flare more than my modern lenses (I need to get a hood).
Wow, that's quite a bargain. It's good to know that should I come across a bargain rigid with front element issues.
The early Summicrons have very soft coatings and it's rare to find one that's not in need of help. The good news is that because of this, they can be found for low prices. I got mine for $50 (exceptionally low, but it needed more work than just a recoat).
The ARAX recoating process can give new life to these great lenses for not a lot of coin.
I think I was the first one here to mention ARAX as a viable source for lens polishing and recoating. The early coatings on Leica lenses are very soft. The lens can look like the surface of the moon, but all the damage usually resides in the coating. Don't assume that "polish" will dramatically affect the lens formula, as it won't, particularly if the "polish" is mostly removing the old coating. I have had three front lens elements from Leica lenses polished and re-coated by ARAX and they all turned out perfect.
These were all lenses that had single front elements, rather than a cemented pair for a front element. I wonder how Gevorg at ARAX would handle the "cemented pair" issue? I also wonder how he would handle front elements that are bonded to a metal ring, rather than being retained by a threaded ring. I believe all of his optical work is done at a commercial lens manufacturing plant where he has contacts. The same optical works that provides lens elements for Arsenal made cameras and Binoculars.
That is why sometimes it takes a few weeks after he gets the glass, as he has to wait until the plant has a coating run scheduled, which is not every day, or every week.
