payasam
a.k.a. Mukul Dube
My coated, post-war Summitar has just come back after having a couple of small spots of fungus removed. The man who did the job (who's in a distant city, which makes sending things and getting them back a problem) did not, however, fix something else I'd told him about. When I can see that the diaphragm is wide open, the aperture ring scale does not show 2 against the index mark but goes well beyond that. At the other end, the ring does not go beyond 8: that is, it does not reach 11 or 16. The front-most element was easily removed by hand, but I did not touch the next ring, which has the aperture index mark on it. After setting the aperture to 8, the smallest that could be reached, I removed the two screws on the aperture setting ring. I saw a brass surface through the holes, with indentations for the screws to engage with. The ring turned freely in both directions. Not knowing what to do, I put back both screws and am again where I was. I understand that the diaphragm assembly of this lens is complicated, so I will do nothing without full instructions. At the same time, the difficulty seems not to be with the diaphragm assembly itself but with the link to it from the aperture setting ring. Help appreciated.
