CharlesDAMorgan
I have a Summitar from 1949 with 10 blades - SN 753333. It is a lens I love, there is a cool rationality about the images - not too contrasty, sharp and with a rendering that I really love, a serenity about them all.
The glass is in excellent condition for its age - some tiny dust and minimal haze, with cleaning marks of no great size. It has a tendency to flare in bright sunlight, which doesn't surprise, and I'm thinking about putting a hood on it to help the issue.
I've seen the rather wonderful, if huge, hinged barndoor type hoods, and have seen it said that there are numerous different versions. I'd be most grateful for help in choosing the right one or alternatives!
Why I love it
And some flare showing in the black of this angelic wonder serving proper coffee after a month of lockdown!
Why I love it
raydm6
Nice photos Charles. I use a Summitar also with the SOOPD Hood. There three types.
Have you seen this?
https://www.rangefinderforum.com/forums/showthread.php?t=57675&highlight=SOOPD+Summitar
Have you seen this?
CharlesDAMorgan
Thanks ray6m6 - a superb link, thank you!
Now out to test it against my DR Summicron as both now have orange filters.
lynnb
How much shading do you need for the front element? I use the screw-in Summitar to E39 adapter + a black E39 protection filter.. this combination gives some shading, but not as much as a regular hood. On the plus side, it keeps the lens small and inconspicuous.
CharlesDAMorgan
A good question Lynn - the second photo was taken with the Summitar orange filter in place, so that is obviously not quite enough. One of the reasons I have been taking it out of the Leica III is to be inconspicuous - I don't want attention to my photographic activities when I'm supposed to be out exercising (a coffee shop stop seems to be permitted!).
02Pilot
Malcontent
I've used a few different combinations, but settled on a simple Chinese 39mm adapter, with a step-up 39-40.5 adapter if I think I might be using filters (I've got an extensive set of 40.5mm filters). My Summitar has not shown itself to be especially flare-prone, so a larger hood isn't really necessary.
LCSmith
On the Summitar I use IROOA without any difficulty, and it also fits the Summicron and Elmar 50s. The only negative is the slight intrusion of the hood into the finder.
CharlesDAMorgan
Thanks again - now to hunt one of the options down! With all the London Leica dealers locked down it's time to have a look in Germany.
CharlesDAMorgan
I've discovered that the Leica vented hood for my Summicron also fits my Summaron, but is a little loose on the Summitar, which given it pings off the Summicron as the will takes it, I'm not sure I'll risk it with the Summitar. I think I might just go for a barn door job, they are inexpensive enough.
However, one of the joys of the old Leica kit is the names they use. Apart from things like the PLOOT and the NOOKY, I've now found there's a hood called the FOOKH. The schoolboy lurking just below the surface had a good giggle with that one.
David Hughes
David Hughes
And try here about post 36 would start things. Here:-
https://www.rangefinderforum.com/forums/showthread.php?p=2951174#post2951174
I'll wish you luck with your search; my one (hood) stays in the cabinet and a plain old fashioned hood from a flea market suits it (the Summitar)...
Regards, David
Regards, David
Dralowid
Michael
From memory I think the barn door hoods have two different types of fitting??? To
do with the clips and how they locate on the lens??? Anyone?
