sun telenet mini 35 on canonet Ql - what is it?
biginovero
5:20 PM
I dusted off a canonet Ql with the 40 1.7, good conditions, got it from nearby town some years ago with a nice tripod and this sun telenet mini 35 add-on lens.
An identical one can be seen here (not mine but identical http://www.worthpoint.com/worthopedia/48mm-sun-telenet-mini-35-lens-tele-305250887)
Now before using it I'm asking if this lens (a doublet, the bigger convex lens is coupled by glue to a smaller negative lens, very simple construction) is a sort of double face contraption that will work as a tele attachment and as a wide angle attachment (wild guess).
This because its separate finder has two frames, one labeled tele, covering about the field of an 80 mm, and a wide labeled frame, which seems to cover a 35 mm lens angle.
Puzzled.
I need obviously to try it but I would be interested in some opinions on this contraption, as well as on the canonet (I remember shooting a single roll with it, results looked like ordinary stuff but lab was not a professional one and prints were small).
Puzzled.
Usually these came as a set of two add-on accessory lenses, with one external viewfinder that had both wide and tele framelines. I believe you have one of the two add-on lenses,
btw, the wide frame of the separate finder cover exactly the same field as the canonet's finder.
Which indicates that this add-on lens was part of a generic set (wide, tele, & VF) that was designed to be used with a 50mm lens. You'll likely find the Tele framelines equally inaccurate.
The lens attachment's simple design is typical of that ilk. It is a simple Galilean telescope. Magnification is typically modest (~1.5x, making the 40mm something around 60mm) and guality, especially near the edges of the frame, rather mediocre.
The Canonet QL with the 40 1.7 lens is a great camera, I used one many years ago with great results. I would use that camera as it is without messing with the tele adapter unless you just want to experiment and have some fun. Enjoy your camera, wish I still had one.
-Thomas
-Thomas
+1. It is truly a great little camera with an excellent lens. Just forget the tele attachment.
