Super weird, 35mm f1.8 2005 issues
rob.nyc1
12:22 PM
I had a filter screwed onto this lens. When I went to unscrew the filter, the entire front element (where it says “W-Nikkor 1:1.8”) screwed off with the filter.
I immediately put it back on, should have taken a photo to document what I’m talking about.
Is this normal? Do I need to get the lens re-calibrated or something?
Next time I’ll be careful not to put the filter on too tight...although this seems like bizarre behavior.
Sent from my iPhone using Tapatalk
Stuff can unscrew. You screwed it back on so you're good. Next time hold onto the front of the lens as you unscrew the filter so it stays together.
I think my Leica Summicron 50 DR unscrews like that.
Totally fine.
My old 35/1.8 did the same thing. Just avoid screwing it all the way out and you will be right as rain when snugged back down.
My lens does it too. Just screw the part of the lens tight inwards so it stays put. Use a piece of rubber (innertube of a bicycle).
Erik.
Thanks to all who replied. Very reassuring.
Erik - how do you use an inner tube to grip it? Do you place it around the circumference, on top?
You just cut a small piece of rubber from an old innertube of a bicycle, say 5cm x 5cm. When it is free from grease and talc powder, you can get a good grip with it on small metal parts. This tool is very often used by camera-repairmen to fasten or loosen small metal parts. You'll be surprised what you can do with a small piece of rubber.
In this case I would fold it around the ridge of the part that comes loose to rotate that part firmly back on its place. The rubber gives a good grip where your fingers will slip.
Erik.
