No.
And yes.
The Leica 50mm lens is a nominal focal length of 51.6mm across all the designs with the exception of the DR Summicron which is 51.9mm. That is in your favor. That said, the lens is designed to put the nodal point 51.6mm from the focal plane but has nothing to do with the physical size of the lens from one design to the next. For example, an SMC Takumar 50mm f/1.4 has a nominal focal length of 51.6mm as well. But it is a retrofocal lens AND it is huge in comparison to the Elmar. The aperture's physical opening in relation to the lens' size is going to be different from the f/stop. Although the lens is a 50mm, at f/2 this doesn't necessarily mean the aperture is 25mm across. It is a representational number that is more arbitrary when actually measuring physical dimensions.
So to simply find a donor lens with 7 good aperture blades isn't enough. You have to know the physical dimensions and match T stops between your lenses to get the same performance.
All that said, you could do it with enough money.
Phil Forrest
